Dj_ciesta wrote:if the coolant level is low will it work if i raise it?i did spill a hole lot because of a accident installing a throttle boddy spacer and hoses
Yup.
The fastest, most official way to get it out is to do what TBW said. There are other less ideal/official ways to do it, such as just pouring in coolant slowly into the radiator. You'll hear a gurgling sound as you fill it up. When the sound stops, stop filling it and let it gurgle, then begin filling again.
I had a coolant leak on another car and it was allowing air into the system as well and I didn't know where the bleeder valve was so I would put some coolant in the radiator so it would gurgle until it was barely full and then squeeze the hose on the other side to force more air out.
