g35 headlights are out
maurice12
Car: infiniti g 35
Need some assistance on how to change the headlights for a g35 yr 2003
adren77
Car: 2004 G35 Laser Red Coupe 6MT
Do you need to change the light bulb, or the entire headlight?
infinititech1
mileage? what are you trying to change? what makes u think its the bulb? just tryin to save you from wasting ur time when it may not be the bulb. cause usually those bulbs last a really really long time
maurice12
Car: infiniti g 35
The light bulb. I have taken everything off but dont see where the light bulb will go.
maurice12
Car: infiniti g 35
Do you know elese it could be? I have check the fuses.
adren77
There was a Sticky of DIY where people posted detailed instructions how to replace the headlight bulb. Anyone have a link to it?
telcoman
maurice12 wrote:Need some assistance on how to change the headlights for a g35 yr 2003
maurice12
Welcome to NICO
Here is a link
http://www.nicoclub.com/FSM/G35/Sedan/2003/lt.pdf
Troubleshooting a non working headlight in a G35 is not anything like any previous car that I've ever owned. There is a page of precautions you need to be aware of when working with Xenon headlights. There are multiple fuzes, a fusible link, relays, and a body control module. You will need a good volt ohm meter as well as perhaps a consult test or OBDll device for reading trouble codes. It might very well be the Xenon bulb but it could also be the HID control unit, or the lamp housing.My 06 shop manual trouble shooting a headlight problem calls for1- replace the Xenon bulb, If still not working2-Replace HID control unit. If still not working 3-replace the headlamp housing assembly
Have fun & let us know. You may want to have your credit card ready
Good luck
Telcoman
W661335PF
Car: 2004 G35 sport sedan-- Mod money goes to 401K
The term headlight(s) indicates that it's both headlights. This points less to a bulb issue and more to something systemic, such as a fuse or lose connection somewhere where both lights intersect to get power or in their grounding.
infinititech1
i doubt its your bulbs
