No need to go to the expense of purchasing new housings. Just buy yourself some VERY mild abrasive paint cleaner... Wax Shop Fine Cut, 3M also has a very good swirl remover. Polish the surface just like you would the paint, working it in until it dries to a haze, then just wipe off the residue. I had a '91 Acura Legend with very yellow and scratched lenses. One or two treatments and they were clear and shiny again. This works for outside surface problems... if the foggy look is from moisture on the inside of the lens, you won't get the desired results.ross6200 wrote:My 2003 G's headlights (the plasic covering) are foggy. It's not condensation, more of a filmy dullness. Anyone have this problem? Can it be cleaned, or can I replace the covering, without replacing all the bulbs and housing?
Well, naturally. I am sorry that I neglected to include that step!ross6200 wrote:Thanks, BigWil! I will pick up some paint cleaner right after I watch the Eagles beat the Giants.....
Yeah...mine is like that, too. There was a little bit of smudge at the bottom right corner so I tried to wipe it off and it hazed up the surface anywhere I happened to wipe. I wonder if it wasn't some sort of glue or something that Infiniti used? I haven't tried anything but Windex to clean it off and that damned sure didn't do anything for it.BigWill wrote:Ok... so let me ask you guys this, since you seem to all have great answers for cleaning the light lenses. My clock face, and dual climate displays are hazy. I think that someone used the wrong product to clean them. Do I need to remove them from the dash to polish them back to clear, or can I do it while they are in the dash?
