joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Mon May 16, 2011 7:18 am
OK, lets think about this...you let your radio play for 15 min, I assume you mean it was with the engine off. So that would drain your battery, which would explain why it started slow. Are you 100% sure that the replacement battery was in fact new? Did you try to jump start the original battery? Really does not sound like a starter problem to me.
Do you have an AUTO or manual? The clutch switch could be the issue. Try pumping the clutch and press it all the way to the floor.
