Tonysg35 wrote:I am looking into buying a 2003 - 2004 g35 sedan or coupe and wanted to know a few things first.
1) Does the car have a driving chain or belt?
2) How offten should i replace it (*driving chain or belt)?
3) Is the engine an interference or no?
Modified by Tonysg35 at 5:57 PM 2/22/2009
Modified by Tonysg35 at 6:01 PM 2/22/2009
I did some research on this as well another poster which answers the questions about it being a timing chain and an interference engine.
I had a timing belt failure before which did wipe at the valves in my old 'H'. I had a timing gear failure (basically a composite gear) failure on a 77 Mustang v-6 which caused not damage. I have had one timing chain failure on a Japanese truck which wiped the valves, so I am not going state that it can't happen since it did once.
However in the case of the timing chain failure there were warning signs such as a strange noise up front and some weird engine running issues. What it turned out to be was a failed tensioner which preceded the rest of the failure.
On the Infiniti it seems that most agree that before the chain fails you'll probably start having other issues indicating an engine rebuild is in your future. So unless it is making noise, I would not worry about it. On the other hand if it is making noise, it is a much cheaper fix (as you seem to know by the question in the first place) and I would really consider replacement unless the engine has high or some really rough miles on it.
Definately don't drive it at 115 mph with 4 people in the car at that point in time.
Perry
