G35 Fan upgrade?
g35sedanlover
Car: 03 Infiniti G35 Sedan
After buying unorthodox under drive pulleys, I tried to order the belts and noticed that the 03 sedan uses different belts (still has mechanical fan). I though I might as well just upgrade the fan as well. Has anyone done this before? What all is involved? I see a fair amount of OEM replacement fans on ebay that say they have factory connections. If I buy this, what do I need for the rest of the connections (what will I plug the fan into)?
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
The fan you want is from a Mercury Sable / Ford Taurus station wagon!
I put this fan on my Hemi Ram it was awesome!
I used thermostatic switch like this to run the high side and wired the low side to come on at ignition!
I'll pm you links to pictures of the install if you want.
Thanks,
Jeff
Modified by gwoods at 7:45 PM 11/15/2007
g35sedanlover
That would really help me out! Also, what CFM should I be looking for?
Modified by g35sedanlover at 4:05 PM 11/14/2007
g35sedanlover
I have a service manual that shows the belt configuration for both electric and mechanical fans and they are the same (IP in place of the fan pulley), but it doesn't show any pictures. Does anybody have a good picture of the belt set-up that has factory electric fans?
bruinbear714
Take a look at this from one of the sponsors for electric fan control...
