Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Fri Aug 15, 2008 6:48 am
If you look on the bottom side of the panel, you should see slots for inserting a flathead screwdriver. This is how it was on my coupe. I assume it to be the same on the sedan.
The very top of the panel slides into where the window goes. So after you've popped all of the clips, lift and it should come out.
Again, this is how it was for the coupe. I didn't read any directions, just go at it slowly and intelligently.
