twineteer »
https://forums.nicoclub.com/twineteer-u52169.html
Tue Jan 09, 2007 3:48 am
Thanks for the great response! I have already changed the Oil and Differential, and found the Trans fluid tube in the engine compartment, but I called the Infiniti dealership to ask about how many quarts of Matic J to use and they told me that the transmission takes 12 Quarts, yes I said 12 Quarts of Trans fluid. And if I just drained what was in the transmission pan, it would only be about 4. So they recommended me bringing it in and having them flush it and adding the 12 quarts of fluid because if I just changed 4 quarts then there would still be 8 quarts in there of old fluid. Is this true? And should I take it to them in your opinion.
