G35 coupe Suspension.. HELP!!
Chung35
Car: Infiniti g35 coupe
Hello everyone,
"i have a g35 coupe"
I was looking to bid on some parts on ebay but i needed help. I found aftermarket suspension for a 350z on ebay, Would that matter if i purchased it and i have a g35? dont the suspension on the z fit the g35 coupe?
Also What Shocks would be a better handling and stiffer ride? KYB- GR2??Tokico-HP??
Wich one would be better?
Thanks! Everyone!
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
350z and g35 are interchangeable...but that means that you will normally swap out the shocks and springs
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
350z springs drop the g35 coupe a 1/2" more than they do the Z. So just keep that in mind. The tokico would be the better choice.
johnparkyourcar
Car: 03 DG coupe 5AT
Tein springs would be the easiest from what I hear since it only drops about 1". with other springs you'd have to get camber kits too from the negative camber...
