How is the output from your alternator? What is your current battery voltage? On my Chrysler this is very important. I can have the battery up to enough to start the car but the car will die instantly if it is not high enough to keep it running which seems a little odd to me but that is what it does. If I charge it a little bit more it will start and continue running. On that car it seems to be about 11 volts or so.apm285 wrote:Hi guys,
Battery went flat a few days ago, battery is about 6 years old as it is an 03 model. Battery cells were gone.
Had the battery replaced. Went to the gas station to fill up about 3 miles down the road. Locked the car then unlocked. Went to start the car and the rpm's went up as normal then dropped which lead the car to turn off. Oil, battery and engine light came on. Second attempt same symptoms. Third attempt turned on however this time the rpm completely dropped just above 0 then all of the sudden went back to 700rpm drove off as car was running. On the third attempt it almost sounded like the car wanted to turn off. Got home locked the car left it locked for about an hour, i again attempted to turn the car on same thing engine turned on, rpm dropped all the way and turned off.
Please help my auto electrician does not know what is wrong with the car. Its an import and was not sold locally in Australia. Basically he has never worked on my car before.
Thankyou very much Yianni
I would lean that direction as well as long as nothing was compromised due to the battery going dead. Was the car sitting for a long period of time before it you found out the battery was dead?apm285 wrote:Hi Perry,
All components were tested including the alternator which puts out enough power to charge the battery.
You see the symptoms dont occur on cold start. It only happens when the car is warm where the rpm range is low on start up, the car either stalls or is about to stall and regains its rev range. It shakes when it is about to stall obviously because it goes well bellow the 500rpm range.
Hmmmmm, i reckon its something to do with reprogramming the ecu, because it has been completely reset. It needs to relearn, Nissan must need to plug their software up and program it.
My son has been having a problem with his Volvo starting when hot. On his it appears to be that the throttle body sits above a cross over between the two banks on his V6. If you open the throttle just a little bit and then try to start the car after releasing it the car starts (and runs normally). If you do not and the car is hot it may not start.apm285 wrote:The battery went dead but it still had some charge in it as i was jump started with one of those booster packs, it started instantly. Battery was original, i can understand it going dead. The car has only done 30,000miles in 6 years lol it doesnt get driven much. Probably on its way over from Japan they sit on those ships for months.
My 1940 Pontiac also suffered from vapor lock. I once picked up a date on a hot summer night in Queens, NY. A few of the neighbors were sitting outside on their front porches watching. After repeated cranking the car failed to start. I had to ask her father for a rag soaked with cold water. I opened the hood and wrapped the cold rag around the gas line where it entered the carburetor for a couple of minutes. The car ten restarted, off we went and we had a nice time.pfarmer wrote:
I don't know on a 'G' if vapor lock is possible but what you describe I have seen on some much older cars (like 50s to early 60s) especially GM products with V8s.
Perry
Had the same problem but it had something to do with playing the 'Fish Cheer' on the 8 track.telcoman wrote:
After repeated calls she never agreed to a second date.
Telcoman
