RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Tue Jan 29, 2008 7:16 pm
Installed a front set of coupe seats. This isn't a straight bolt in affair. Had to do some rewiring because the coupe seat has a control module in the seat and the sedans control module is somewhere else. So I had to rewire harness plugs from the sedan onto the coupe seat for heater/power. The airbag and seatbelt plug was the same. I had to rewire the controls from the sedan seat over onto the coupe seat because we couldn't get the forward/backward switch to work, the up/down adjustments and recline worked fine. We also had to bypass the control module for the forward/backward motor and tap straight into the wiring harness for the controls. Then everything worked like it was suppose to. The seats set lower and the passenger seat sets much lower. I just installed spacers today to raise the back up about a inch and the front 1/2 inch. Sets perfect now and wifey approved, because she couldn't see over the windshield wiper arm. The seats are very supportive as you can see from the bolsters in the pics. Enjoy and it was worth the time and effort.
