How oftern do you change your air filter and when is the last time you changed it? How often do you check your tire pressue? How much weight do you carry around? Perhaps the wife gained a few pounds? How many miles on your car?enflixer wrote:I keep track of my MPG and track it with the computer in my 2004 G35 Coupe. Over the past few months I have really noticed a dip in my MPG. I was getting at least 300 miles out of one gas tank fill up and sometimes higher, no matter how I drove it and with what ever gas I put in it. Now I am lucky if I am getting 275 a tank full. I have tried different things like using different grades of fuel, you know the 87, 89, 93. There is no difference that is noticeable. I have added stuff like the upper cylinder lubracant to the gas, I think its called tune-up in a bottle and was recommended by a mecanic at the dealership. It seemed to work for a while but it's not helping now. What I am thinking is my car either needs service or maybe the quality of gas has gone to sh$t with the addition of the ethanol. Anyone have any guesses?? This problem is getting expensive!!Thanks
When was your last tune up? Have you ever had a valve adjustment or your fuel injectors cleaned (not just the stuff they sell in the bottle)enflixer wrote:I keep track of my MPG and track it with the computer in my 2004 G35 Coupe. Over the past few months I have really noticed a dip in my MPG. I was getting at least 300 miles out of one gas tank fill up and sometimes higher, no matter how I drove it and with what ever gas I put in it. Now I am lucky if I am getting 275 a tank full. I have tried different things like using different grades of fuel, you know the 87, 89, 93. There is no difference that is noticeable. I have added stuff like the upper cylinder lubracant to the gas, I think its called tune-up in a bottle and was recommended by a mecanic at the dealership. It seemed to work for a while but it's not helping now. What I am thinking is my car either needs service or maybe the quality of gas has gone to sh$t with the addition of the ethanol. Anyone have any guesses?? This problem is getting expensive!!Thanks
I doubt a valve adjustment would be necessary. IIRC, the G35 uses a shim-on-bucket lifter design. It's notably lightweight and requires the lowest spring rate of any design so it typically has a low wear rate. When I had my 240sx, I had replaced the valve stem seals and the shims showed very little sign of wear at some 100K miles. Used the same lifter design.Floppydiskz wrote:
As far as the topic, itself, I'd check the air filter, plugs and fuel filter. Perhaps even the O2 sensors.
Don't assume your tire pressure remains the same. Tire pressure @ 35lbs measured in December with the temperature at 40F will not be the same in February with the temperature at 20F. Obtain a good quality tire pressure gauge & don't rely on the ones at gas stations. In the winter you need to add a few extra lbs to account for temperature drops.How are you calculating your mileage? Some gas stations post 10% ethenol and others post 15%. My mileage was 22.4 MPG when I filled up this morning. It drops in cold weather and improves to between 23 & 25 in warmer weather. I only use regular 87 octane. BP posts 10% ethenol where I fill up.enflixer wrote:I will try that stuff. I wish I was getting 20 mpg, I was use to getting about 17-17.8. Now I am getting like 15.2, this is why I am getting a little worried about something being wrong. You guys have helped a lot. The tires are the same size by the way. I am due for an alinment so I will get that done. I get one every 3-4 months just to save the tires. I have had problems in the past. Thanks
Correct me if I'm wrong but I think Riverside,Ca is near LA?If so you do not experience the wide temperature swings that we have here in the east. We can reach 100 F in the summer and zero or below in the winter. There is a drop of a few lbs for each 10 degree change in pressure. Also some tires will lose a few lbs over time the same as women tend to gain a few over timeSentientbydesign wrote:Telcoman:
I'm not trying to argue with you here, just trying to make sense of something. I don't check my tire pressure religiously, but I've never had a drastic drop in pressure over time.
I did have one occasion where I lent my car (not my G) to a friend and it came back with 50 psi on one tire and a "replaced" valve stem cap
Other than that, the pressure was always within 1-2 psi.
