help us help you:
1. Post a video please with clear audio.
2. Any CEL's? (check engine lights)
3. Any oil consumption? ( have you been keeping an eye via the dip-stick?)
4. Any blue smoke from the exhaust pipe?
5. any chatter upon start-up? (the synonymous timing chain noise)
your 3.5L is known for oil consumption. running low oil levels will cause deadly internal engine damage. if your not adding oil to your engine, your going to get worn piston slap, valve train noise, or worn/spun crank bearings that will cause the crankshaft to 'dance' in its bearings.
is this the noise?
[youtube]
http://www.youtube.com/watch?v=DvmlchfBaE0[/youtube]
