Sounds like you put the positive battery terminal to ground which will start a fire.asuliman1 wrote:HEY, IM HAVING AN ANNOYING ISSUE WITH MY 04 G35 COUPE. EVER SINCE THE FIRST COLD WEATHER STRIKED ID WANT TO TURN MY CAR ON AND IT WONT START ONLY WITH A JUMP FROM CERTAIN CARS... IT WOULD BE GOOD FOR A FEW TURN ON/OFFS AND THE SAME PROBLEM OVER AGAIN. I WENT TO A MECHANIC HE SAID I HAD A LOOSE GROUNDING CABLE SOMEWHERE SO HE PUT A GROUNDING WIRE FROM THE ENGINE TO THE BODY ITSELF AND IT RAN FINE FOR TWO DAYS ...CAME TO WARM IT UP BEFORE WORK AND IT WOULDNT START AND I HEARD A CRACK SO I OPEN THE HOOD AND NOT THE GROUNDING WIRE HE PUT BUT THE OTHER ONE ON THE ENGINE TO THE BODY ( RIGHT UNDER THE INTAKE) AND IT WAS CRACKED IN HALF SO I GO BUY ANOTHER ONE AND REPLACE IT SOMEWHERE ELSE TEMPORARLY AND IT CAUGHT ON FIRE SO I LEFT IT AND TOOK MY MOMS CAR TO WORK.... ANYBODY GOT A SINGLE CLUE WHATS THIS ABOUT ???????? ID REALLY APPRETIATE IT AND NOT f*** IT UP MORE THAN IT IS![]()
