SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Wed Sep 03, 2008 2:01 pm
Congrats on the new to you Coupe.
I have wondered if the switch between the two slightly different combination meters was possible.I like the 05 better personally the gauges have a beveled edge and that interesting little shift light. As for the the gauge swap, the wiring connectors are different. The 04 uses two 22 or so terminals, and the 05 uses one 40 terminal. I don't think it would be advisable rewire the existing harness as there are CAN lines that are very sensitive to any additional resistance in the circuit. Also the combination meter converts the analog wheel speed signal to a digital pulse signal that the ECM can decipher. It would be a neat swap though if you do it.
