G35 camber??
andrewjetmitchell
Car: '05 G35
I know on the G35 coupe the front wheel camber is set in a bit, but is it also on my 05' sedan? If yes? Why keep buying new tires that will keep wearing out prematurely? what are yall doing?? Jet
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The camber is not wearing out your tires, it is the toe setting. That is why there is a Technical Service Bulletin to try and correct the problem. Toe needs to be set to max toe-in. This will help eliminate the feathering problem, but will not cure it completely.
andrewjetmitchell
Car: '05 G35
The technical service bulletin, can this only be done by the dealer or can we have someone else make the change? And where can I get a copy of the bulletin? Thanks Jet
joe603
Car: 2014 Durango R/T
Here you go. It's a link from the G-Series FAQ page
http://x.infinitihelp.com/foru...id=83
