2003 G35 Coupe.Ok so I did some maintenance on the G35 today. I changed the oil, cleaned the throttle body with TB cleaner and rinsed off the engine.
I went to start it and it would not start just crank and crank..
I tried again 5 minutes later and it would start then die..
I just tried it (maybe a hour later) and it just cranks..
So... is it that I cleaned the Throtle body? I opened it with my hand when I was spraying it.. could that have messed up the drive by wire setting?
or is it that something is shorted from the water? should I just let it sit and "Dry off" and hope it fixes it?
In the past when I would rinse off my engine I would start it right away to dry it.. well I can't exactly do that..
