G35 Brembo brake upgrades
Member area: Post up your ride and the modifications to date
IlsG35
Car: 2003 graphite 6speed G35
Cross drilled & slotted rotors 350z/G35 (Brembo)
Z1 Motorsports 350Z / G35 SS Brake LinesATE super blue brake fluid
Hawk HPS Front Brake Pads 350z/G35 (Brembo)
Hawk HPS Rear Brake Pads 350z/G35 (Brembo)
Installation difficulty - Easy
Install time - About 4 hours
Cost - approx. $800.00
Advantages - Looks good and stops a whole lot better. The hawk pads also help reduce dust and they last longer then stock brembo pads and rotors. Super blue racing brake fluid has a higher boiling temp then normal fluid. Braided lines help with improvement of braking.
Disadvantages - None
Dj_ciesta
Car: Infiti G-35 2005
where did you order. cause that is cheap.
IlsG35
http://www.z1motorsports.com/3...=2241 theres the link to it an it cheaper then i had said i had gotten all these mods done almost 2 years ago its $550 now fo everything i mentioned... its only for brembo brake system... they have it for base models too..
JeromeS13
Car: 2008 Subaru Impreza STI
teppy wrote:I AM A SPAMMER AND G_WHIZZ BANNED ME
I understand all of those words. However, I have no idea what you're trying to say...
G_whizz
Car: 2010 G37 Coupe Sport
Return to “G35 and G37 Modification database”
