G35 Brakes
mrfixit555
My rear right brake pads wear out quickly. It is very difficult to remove one of the caliper slide pins so I'm thinking this is the problem. It appears to have a rubber tip. I have never seen this before. Is this normal or should both pins be the same?
OriginalWheelman
Car: '15 Ford Focus Electric
I can't answer your question but if you post here...
zeroforum?id=102
someone should be able to help you.
Welcome to NICO!
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
coupe/sedan?
what year?
how many miles of wear?
even or uneven wear?
NEED more info...
mrfixit555
2004 g35x sedan. Right rear brakes wore down to metal after about 20k miles. They were aftermarket ceramic pads. Both pads wore down equally. Left side was in good shape. The original pads lasted until 70k, but they also failed on the right side in the same manner.
tollboothwilley wrote:coupe/sedan?
what year?
NEED more info...
