G35 Auto Stock Vs. 04 SRT-4 Neon from a 60mph roll
uno
Ok me and these guys on srt forums are kinda going back and forth because this guy with a stock 04 srt4 says he just walked away from a G35 from 60 to 100+..they're saying because the g35 had a passanger and the srt didn't and the srt had it's spare tire removed that i'm an idiot for thinking that the g35 should have won....They said that the 50hp advantage it has on the srt-4 is negated because of the drivetrain loss and the extra 500 or so pounds....I said that's what the torque is for, and they still act like i'm dumb...Am i really that far off base? Shouldn't a g35 walk away from a stock srt-4 Especially on top end? I even showed them the drag coefficient for the g35 at .26 and zero front end lift and they said that doesn't matter even when their srt4s are horrible non-aerodynamic.....Help me out guys, lemme know if i'm totally wrong or if it should have happened that way....Thanks in advance...
rydwhite
Car: 2003 Infiniti G35 Coupe
They may have walked the G35 from 60-100 if the G35 driver didn't know that they were racing, but otherwise I don't see how it would be possible from what you've said. Unless maybe the passenger weighed 400 pounds. The SRT's are quick, but the G really performs well from 60-130 in my experience.
uno
that's what i thought too, i thought 60 and up was when the G35 really shines....ok just making sure i wasn't going crazy or anything
rydwhite
I know they both have similar 1/4 times about 14.4 or so, but from a rolling start at 60, I just don't see that happening.
JPRempe
In my very honest opinion, they are so close to each other in ability that it is just too close to call. Drivers race. From a roll, the SRT4's are quite deadly. G35's would have a momentary advantage from a very slow roll or from dead stop. The SRT4 has a hard time hooking up since it gets into boost pretty darn quickly. From a roll, they could run the gears correctly to maintain close to full boost, and that's just not easy to overcome. Also, keep in mind that their engines are underrated. They have a bit more TQ/HP than advertised.
Phax
Car: Control dynamics
I starting walking away from a G35 coupe by the top of 3rd gear. An SRT-4 will own my car. The only way your G35 is going to win, is if that SRT-4 has a speed governor.
I could be wrong though. I only raced the G35 up to about 90mph. At that point, I was pulling on him.
Don't feel bad though, you can pull women with a G that wouldn't go anywhere near an SRT-4.
stillmatic
You guys have too much pride... The 04 SRT-4 runs 13's on the quarter mile. Maybe if it was the 03 SRT-4 against a G35 MT Coupe then it would've been a different story.
rydwhite
I didn't realize that the 04 SRT was that fast. Damn. Well, nevermind then. I guess it is possible. I could have sworn that they were only running 14.4's in the 1/4 though. Oh well, just another reason for me to throw that dream works sc in there.
nismokid
so far every stock srt4 ive seen at the track was hitting about 14.4, the fastest ive seen at a track was 14.3, that was stock and theres always a bunch of them at the track
stillmatic
Here's the difference between the 03 and 04 SRT-4.
03 SRT-4No LSD215 @ 5400rpm horsepower245 @ 3200rpm ft/lbs torqueBest 1/4 mile time: 14 secs flat
04 SRT-4Stage1 Mopar upgradeLSD230 @ 5300rpm horsepower250 @ 2200rpm ft/lbs torque1/4 mile time: mid 13's
rydwhite
interesting, I didn't realize that they made an upgrade from 03 to 04.
uno
cool deal guys thanks.....not a pride issue i drive a 93 240sx not even a g35 or an srt4.. i just didn't know, figured the 280 hp and 270ft/lbs of torque would help some since srt4s have problems with cars with less power and about the same weight but i dunno...what i don't understand is how some magazine ran a 13.7 with a stock 350z and a 13.7x with a 04 srt-4...but i have seen numerous ones run at a track and both cars run 14s consistantly....so oh well, just checking...
JPRempe
stillmatic wrote:Here's the difference between the 03 and 04 SRT-4.
Your information is incorrect. The '04 SRT4 does not have the Stage 1 MOPAR upgrade. That is still a seperate purchase. The only differences are that they rated the engine closer to what it actually makes (still underrated) and added the LSD unit to all '04 production vehicles.
JPRempe
uno wrote:cool deal guys thanks.....not a pride issue i drive a 93 240sx not even a g35 or an srt4.. i just didn't know, figured the 280 hp and 270ft/lbs of torque would help some since srt4s have problems with cars with less power and about the same weight but i dunno...what i don't understand is how some magazine ran a 13.7 with a stock 350z and a 13.7x with a 04 srt-4...but i have seen numerous ones run at a track and both cars run 14s consistantly....so oh well, just checking...
The SRT4 puts right at or slightly under those "factory rated" numbers to the wheels...so add 15% to the Dodge published numbers and you'll have a better idea on what they really make. Then they have the not so expensive Stage 1 and now Stage 2 upgrades from MOPAR performance.
The SRT4's you see at the track are just having a hard time launching. If you launch too low RPM, you bog...too high, you smoke the wheels forever. It has to be a perfect launch to get those mid to upper 13's on the SRT4.
And as far as power to weight ratio, the SRT4 slaughters everything it competes against. It weighs 2900 lbs and has a real crank HP rating of right at 260 HP (and 280~ish TQ). Compare that to the G35C which weighs 3435 lbs and has a crank rated (and very accurate for once) 280 hp (270 tq).
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
from my own experience, ive seen an o3 srt4 go at it with a 35oZ from 4o-12o, the srt4 had it won until about 9o mph, then the Z took it up top, but id say an AUTOMATIC G wouldnt stand much of a chance agains those potent lil buggers
Phax
JPRempe wrote:And as far as power to weight ratio...
That's what really matters. Just think of a go-kart. 125cc engine, 100+mph.
uno
Cool thanks guys....
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
You end up loosing something like 15-20% of your power from the crank through the driveline with an automatic. I am not sure how much power from the crank the automatic G-35s loose. The G had some important obstacles to overcome. Added weight from the vehicle and passenger. Parasitic power loss through the drive train. But I think a lot would have to do with the gearing of both cars. I would tend to think that the SRT-4 would win this race on paper, but who really wins the looks department? Which car gets the chicks?
JPRempe
Cold_Zero wrote:You end up loosing something like 15-20% of your power from the crank through the driveline with an automatic. I am not sure how much power from the crank the automatic G-35s loose. The G had some important obstacles to overcome. Added weight from the vehicle and passenger. Parasitic power loss through the drive train. But I think a lot would have to do with the gearing of both cars. I would tend to think that the SRT-4 would win this race on paper, but who really wins the looks department? Which car gets the chicks?
Who cares about the shallow whores that you can only pick up with a certain type of vehicle? I sure as hell don't. And besides, we're debating performance issues here, now talking about the best way to contract STD's...
Cold_Zero
I was joking around with my last comment. Good women typically dont give a rat's *** about what type of car you are driving. Calm down and switch to decaf. :eyecrazy
JPRempe
Cold_Zero wrote:I was joking around with my last comment. Good women typically dont give a rat's *** about what type of car you are driving. Calm down and switch to decaf. :eyecrazy
Forgive my outburst. Wife was at work and I was wanting to "play" with her today...
:ylsuper
Cold_Zero
I understand completly.
nlzmo400r
sonuds like everyones much nicer to each other when they get a lil bit eh
rydwhite
Haha, yeah, that's usually the case.
nlzmo400r
i know it always is with anyone i know. I bet if everyone just got had more sex with their partner, the world would be a happier place, besides, i bet road rage would quiet down a bit too
wantasupra3
My friend has a Srt 04 and the thing will beat my g35 sedan auto. i have never raced it but have driven it. The Neon has a really flat 3 gear! but it would take the automatic in 4th if the turbo doesnt loose breathe.!!!
thats my .02
nlzmo400r
yea, hell the o3s were quick , and now that almost 2o percent of o3 owners bought the mopar stage one package that ups em to 24owhp and 26o ft lbs of tq (closer to wheel numbers there!) they're even more deadly
