C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Feb 05, 2006 7:39 pm
For those of you with a G35 with 18 or 19" OEM wheels or 350Z with 18" OEM wheels and 245/45-18 rear tires, please respond:
Please list which wheels you have (Touring/Performance 18", Track, Anniversary Edition, non-RAYS 06 wheels, 18" or 19" G35 wheels) and if you are having any issues with accellerated wear on the center tread of the rear tires.
What I am looking to determine is if the 8" wide wheels with a 245 wide wire is causing the center tread to bow out slightly. The 350Z Track, Anniversary Edition, and 06 non-RAYS 350Z and the 19" G35's have 8.5" rear wheels with 245's, so if these do not have this issue, and both the G35 18's and 350Z (Touring/Performance) 18's do not, then I think it will confirm if this if the reasoning behind the problematic tire wear.
I just did an oil change over the weekend and noticed my rear tires that I put on a bit over 9,000 miles ago are toast already. The tread on the shoulders have plenty of tread, but the center tread is down to the wear bars and the other one is right behind it. The front tread is still good all around as are the front OEM Michelins that came with the car. In fact I have the front OEM Michelins in my garage as they were still good at 14,000 miles.
So basically, you need to have OEM wheels and OEM tire sizes to respond to this:
Car: (350Z or G35)Wheels: (19" G35, 18" G35, Performance/Touring 350Z 18", Track 350Z<not 06>, Anniversary Edition, or 06 Non-RAYS 350Z)Rear center tread tire wear: (yes or no)
thanks in advance
