G35 and 350Z automatic transmission swap
maplemotors
Will the automatic transmission out of a Nissan 350Z interchange with a Infiniti G35 coupe automatic transmission ?
Q45tech
Early 5AT had an external TCU while 2004 [varies by month] to current have an internal TCU.
If the number of connectors and harnesses match.
There may be slightly different software in TCU whether internal or external between G and Z. If diff gear ratios are identical a swap will probably be functional.
