loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Jul 19, 2007 9:29 pm
The compressor will never engage in ECON mode. Ventilation is provided by the blower. In ECON mode, if air RECIRC is selected, you can have fogging on your windshield and windows due to condensation. To avoid this, you can crack your windows/sunroof open, or select Fresh Air. Your airconditioning system, aside from cooling (heating) the cabin, will also de-humidify it. With the compressor off, the evaporator can no longer function hence the possibility of condensation in the cabin. I usually go in ECON mode if the outside air temp is low.
The 'stink' in the AC system is usually caused by molds in the evaporator area. In humid condition, frost could form in your AC line, particularly in the evaporator area, while in Normal/Max Cool mode. Frost turns into water when you shutdown your AC or your car. Water/moisture induces mold growth. This problem could get worse if your drain line is restricted or clogged.
By switching from Normal to ECON mode on the last few miles of your drive you are allowing the evaporator area to dry up, avoiding mold formation.
If your AC smells bad, replace the cabin air filter and make sure the drain line (tube on the undercarriage, pax side) is not clogged. Then use BG Frigi Fresh (I mentioned earlier) to kill the mold. Ozium will also do the job but it's more expensive and some people don't like it's smell. Ammonia is not recommended since it's strong and can cause corrosion, etc. You can get discounted pricing for Infiniti/Nissan parts from Joe (Scottsdale Infiniti a.k.a "everything nissan.com or "InfinitipartsUSA.com), one of our NICO sponsors.
Rod97&03 Q45s97&99 I30s04 G35
