slice235 wrote:Hello,
I own a 2004 G35 Coupe with 49K. The car is running great, brakes are solid, acceleration smooth, and no other misc. issues as I can detect. My dealer has contacted me to have the 50,000 service done on the car. Below is the list of tasks to be done for $1,200:
Lube ,oil and filter
Air filter replace
In-cabin filter replace
Wiper blades
Brake fluid flush
Cooling system flush
Transmission fluid service
Differential fluid service
Drive belt replacement
Tire balance/Brake inspection
Consult system check/ Emissions diagnostic
Multi-point inspection
Wash and vac
I have an independent garage who have serviced my BMW for years and is excellent, however I'm not too sure his experience with Infiniti. I think I will have him perform a basic overall inspection and just fix what is needed. Any comments with respect to Infiniti vs Independent garage for this level of service.
The other issue is my Powertrain Warranty expires in November. I am thinking to take my G35 to my independent garage to check-out the car but specifically review all Powertrain systems to determine if there are any issues. If so I could then take the car to the Infiniti dealer for warranty service. Any suggestions on specific things that should be checked on the Powertrain.
Thank you
Welcome to NICO
You will find lots of opinions here but here is my $.02
Those dealer recommended services are written for those people that never lift a hood to inspect anything. Most wives for example that just put in gas and go
If you change your oil, oil filter, and air filter regularly, check your tire pressure, and rotate your tires all of this can be done yourself saving you quite a bit of money. You'll know when to replace your wiper blades because it will become difficult to see. The blade inserts can be purchased at Infiniti parts and the service guy even showed me the little trick for inserting them. Takes only a few minutes and they are cheap.
I had new brake pads and rotors cut at 85k miles so thats when the brake fluid was flushed.
I had my plugs replaced at 106k miles so thats when the belts were replaced.
I've done 38 oil change & filter replacements every 3k-3.5k miles and change my cabin filter once a year
I've skipped the 15, 30,45,60,75,90 & 105k mile services.
Still have the same transmission and differential fluids with no problems.
BTW I've had vehicles with almost 250k miles on the same transmission and differential fluids with no problems
Your decision
Telcoman
