jsemelgar wrote:My radiator fans don't come on. The two fuses near the battery are good. When I ohm the radiator fan motors they show an open line on Black & Green wires, but show micro ohms on Blue & Yellow. I ran power straight from the battery to the fans but they did not turn. I don't see a fan relay, if there is one on this car. The parts guy at the dealership told me over the phone that it sounded like the fan motors are bad. I also disconnected the wiring harness at the fans, turned the ignition to ON (did not start motor) and checked for power going to the fan. Unfortunately (if I checked it wrong) I did not get power coming from the wiring to the fan. I don't see any fan control module on fan motors and I see no fan relay.
Any suggestions would be appreciated. I think you in advance for your replies. Jim.
I couldn't pull up the link for the 2007 coupe but the sedan has a relay and a fan control module
http://www.nicoclub.com/FSM/G35/Sedan/2 ... dan/co.pdf
http://www.nicoclub.com/FSM/G35/Sedan/2 ... dan/ec.pdf
Cooling fans are controlled by cooling fan control module. For details, refer to EC-23, "Component Parts Location".
Disassembly and Assembly INFOID:0000000000956350
If you are still under warranty take it to the dealer
If not ask for an estimate
Good luck
Telcoman
