alphapig wrote:beeristasty wrote:You may need shank style lug nuts. Looking at the lug nut's contact surface on the rim will confirm.
And an alignment would be a good idea if you haven't gotten one in a while (or got one done with tires that have excessive camber wear).
So much speculation, why even post dude?
Regular tuner lug nuts with a cone seat work.
Alignment is always a good idea. But save the expense for when you actually touch the suspension, or if you eat a curb.
Damn, ok, someone must've gotten a sack of coal for xmas. I don't see where the "so much speculation" comes in, so please elaborate to me via pm. Infiniti has used shank lugs for some time now, so I just wanted the OP to do a little research on his own to make sure he's got the right lugs that fit his rims. Why? Because I searched and I came across different answers.
I've said before that not everyone knows what they're talking about and will post all sorts of bad info because they think it makes them look knowledgeable. No matter how well intentioned, it's still bad info. It happens all the time on every forum I've been on. I'm obviously not calling you out, you have proven over time that you know what you're talking about. But sometimes the only way to be 100% sure is to do your own research.
So moving along with a real-world example: my oem conical lugs do not work with my aftermarket rims w/conical seats. In theory, they should, but the nut head is too large to get a lug wrench around it without severely marring up the lug holes.
Since my speculation appears to multiply exponentially when you read it, here's the part that will blow your mind - unless you have on good accord that the oem lugnuts from an AC's 16" alloy wheel will fit on a 19" G35 rim (which they may very well do), how do you know that this previous post of yours is true? If you do, then you should tell the OP so then he will be all set and we can call it a thread. And if you don't, you've inferred that it would when there's a chance that it won't. In which case the OP would have found out soon enough.
alphapig wrote:
Wow ridiculous price for G35 Rays!
Just slap them on.
Everything will fit perfectly, including the center bore
