g20 wont start
blademaster2444
Car: g20
ok i just changed all four injectors on the car and now it wont start. is there something special i have to do to get it to work after changing the injectors?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What year?
Any Check Engine Light codes?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Hopefully you "oiled" the injector o rings when you put the injectors back in. If not they will leak and flood your cylinder(s) and it won't start, period.
Infinitiguy19
Well your technically right because starting it would not be safe if the O-rings are at fault. But holding down all the way the accelerator while cranking will signal the ECU through the (Throttle Position Sensor) to not open the injectors which will eventually clear the cylinder(s) of fuel.
So check the cylinders before starting to make sure you don't start the engine with a cylinder full of fuel.
