G20 Upkeep/Modifications
Stark020
Car: 1991 Infiniti G20
I bought a 1991 Infiniti G20 from a friend of a friend about a year ago. The car has been sitting in my yard for quite some time. I got it registered and started to drive it around a bit and noticed a few things that are off on it. Now, I'm no car guy. Not by a long shot. I can tell though, that the suspension parts are worn out. Tie rods need replacing and the upper control arms as well. I've replaced the lower control arms. It leaks oil from the pan, but that should be an easy fix. There's a radiator leak. It jerks when going from first to second gear. It's an automatic, by the way. So there's definitely things that need to be done. Where would any of you recommend I get parts for this car? AutoZone seems to not have the parts for it. Are there any sort of modifications that would make this car stand out (look/sound better) after it has been repaired to a decent level? Is there anything I should do performance wise? Thanks in advance!
https://youtu.be/7LMG9ydwQos
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Welcome to NICO! Most of the OEM parts can be found at local parts stores, rockauto.com, or in a pinch, the dealer. For more performance oriented stuff or parts that are harder to find, you can try GSpec.com or any of our parts vendors (look at the ads). Finding a used auto transmission isn't to hard, you can try car-part.com to search nationwide wrecking yards. If you want an exhaust, check out brmexhaust.com. That's what I have, and you can configure it anyway you'd like which is cool. If you don't have foglights, find one in a wrecking yard that does and grab them foglights, brackets, and the switch inside on the dash. All the wiring is there from the factory, you just need to cut the holes on the bumper and bolt/plug everything in. It helps the looks of the car a ton. Hopefully that helps!
