g20 turbo up and running slight problems...
JEdi 240sx
Car: 1989 240sx KA24ET
hey guys been a while since i posted. but thanks for all the help finally got the car started and running, but not really running right. turns out the fuel rail was slightly bent ( i know i hate saying this but the injectors were the only thing i didnt install on the project someone else did....so the rail was actually really bent) it would start up whenever we had it unbolted and just sitting on the manifold. took it off hammered it straight. changed all the plugs again, and damn after those 2 simple things it started right up. now for the fun part...so the car has blueish white smoke whenever its in gear. usually that means its burning oil, never did that before. so more than likely has something to do with the turbo. along with that the car bogs at around 4000 rpm. i have a feeling i might have it set to run too rich so hopefully thatsthe cause for the smoke and the bog. i'll go back and check timing as well. in any case thanks guys for all the help, let me know what you think. ill try and have pics by the end of the day.
Erm
NISTECH
If the smoke is blue I would be thinking possible blown seals in the turbo. If it is kinda white/gray in color I would say its running fat. Maybe one of those injectors got cracked when you were fixing the rail??
