SR20drftSX »
https://forums.nicoclub.com/sr20drftsx-u38806.html
Sat Jul 28, 2007 4:24 pm
or some sort of steering problem . this started happening after i had the clutch replaced with a stock quality exedy replacement. i get the car back and begin driving , first a hear a few lil pops from the front left and then in pretty much every gear except 5th , when i am accelerating my steering wheel will turn itself left to about a 65 degree angle and my wheels (tires) will turn right !!!
i stick my head out the window and i can actually see my drivers side front wheel turn in all by itself when i am accelerating , this happens especially when i am in 1st , 2nd, 3rd, and 4th gear , and sometimes in 5th under 60mph.
also when its under power making slightyl sharp righthand turns or any turns to the right pretty much , and sometimes once its turned or (snapped) in , the wheel will just like stay there and ill have to pop the clutch or hit the brakes to correct it .
this does it also when im goin up a slightly steep hill , especially on dirt roads , yes i live near dirt roads , decently groomed dirt roads that is.
well its buggin the **** outta me and ive changes tons of stuff that mechanics have said that it was, : i changed the rear struts , gotten the entire car alligned, changed the transmission mount , gotten new tires , and changed the drivers side CV drive shaft/axel because the recent mechanic said it was broken , and also replaced that seal. i just dont understand what could be causing this.. any help is greatly appreciated.
thank you
Garrett H
