This is the adapter you mention?Faja wrote:I believe you can buy a Nissan 14 Pin to OBDII 16 Pin adapter so it will work with your ScanGuage but I'm not sure if it will provide the exact same functionality. Maybe you can call the ScanGuage manufacturer and get some more info or if that will work.
Did you try getting in touch with Scanguage's Tech support and see if they can help or even call Nissan and see if what you're trying to do is possible. NewKleer could be on to something with the pinouts not matching also.nicoxis wrote:Today my Consult/odb2 adapter arrived with no luck, scan gauge got stuck on "connecting". Tried forcing all of the different protocols with no success.
And Peter, I don't think I'm getting any other device soon, maybe later this year. Thanks for your time anyway.
