Hi,
I have several problems with my Primera/G20 after engine wash few days ago.
It wasn't pretty weather to do such thing but I had to since I had some oil leak due to bad head cover gasket. I left car for two hours to dry before I started engine. At first everything seemed to be OK. After engine have wormed up the misfiring problem occurred. OK, that was fixed by drying spark plug holes and cables, but I have noticed two other problems. Los of power and shifting problem from 3-4-OD.
Bad acceleration and low power occurs occasionally mainly 1500-3000 rpm and disappears after 5-10 sec. What worries me is that transmission shifts from 1 to 3rd just fine and stays there, no 4th gear no OD. One more thing I have noticed is that shifting from D to 1 is useless since it acts like it is in D all the time.
I know that probably I have to wait until entire assembly dries out (I have mentioned here is wet weather past days) but I am worried if some parts can be damaged for good.
I didn't mention that nearest decent mechanic is 60 miles away and there is nobody who is able to fix A/T in the circle of 500+ miles, so I'll have to do everything by myself. Where to start?
Thanks
Modified by ziik at 6:34 PM 4/16/2008
