G turned 100
joe603
Car: 2014 Durango R/T
kmckis1029 wrote:
370Z/28 wrote:Yeah Kay...how many of those miles are quarter miles?
was at the track only for test/tune 2 weeks ago... but got about 6 runs in this year so far... they dont time at atlanta motor speedway and its 1/5 mile...
You should check out Silver Dollar Raceway in Reynolds GA! Took my 97 Formula there years ago for an F-body meet when I was stationed at Warner Robins.
http://www.silverdollarraceway.com/
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
telcoman wrote:First set of brakes replaced and rotors cut 2 years ago at 84946 miles. 43 oil changes thus far
Telcoman
Telcoman is my opposite when it comes to cars. I am bizzaro Telcoman.
I run EBAY drilled and slotted rotors, never had any issues with them. I run a set of pads for either 20-25k miles or 1 track day. Then clean up the rotors with a sander and 40 grit. Install a new set of pads without turning, can't find a place in Phoenix that can turn drilled and slotted.
The thing we have in common is neither car has had a major failure. I have had two that were wear/design failures.
Idler pulley bearing seized at 98k and a cam shaft position sensor started failing intermittently.
