naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Sun Sep 03, 2006 7:11 am
Ughh a lot of bad data going around in this thread. As C-Kwik said, when using those g-force box things, or any in-car readout, the number that you hit means absolutely nothing. They are far too innacurate. You can be pretty sure that they are precise though, which means that they are good for recording consistant numbers with a given setup. This allows you to tweak suspension stuff on the car, and see if you can get a gain in lateral g's. Neither number by itself will tell you anything, but you can certainly make conclusions from comparisons.
As Greg said, 1.0 g is pretty much the gold standard that everybody aims for, seeing as how this is around what the top sports cars pull. Remember though, this is not a "peak" lateral grip number. This is an average. They get these numbers from driving around a large flat skidpad in consistant circles and timing how long it takes to make a few rotations. From there, physics will allow you to find the lateral grip data. What you end up with is the average amount of lateral g's that the car was pulling for the ENTIRE length of the circumfrence, not a maximum number. Hitting 1.0 g maximum is not too entirely difficult. Hitting an average of 1.0 is.
Of note: Sport compact car hit 1.0 g with their s13 project car. They were running coilovers with 6/5 springs, aftermarket suspension links, a helical differential, front and rear adjustable sways, and some 225/45/17 Falken Azenis 215's. The tuning of the car is the most important thing. You have to spend time trying different alignment, sway and damper settings.
