ejXa q45 »
https://forums.nicoclub.com/ejxa-q45-u34266.html
Mon Dec 11, 2006 1:48 pm
G 50 problem, what is it i need some idea 's what this could be i posted something before but this is the hole story from day one my q had a vibration first it started at 40 mph and 50 mph with a violent bucking and jerking and also it shake in any gear while driving or parked this happened after the violent bucking. so i fix and cleaned MAF, throttle body and ACC no luck. i started to loose power when i could not find what the problem so took the car to a mechanic and he replaced coils and plugs still this did not fix the problem ...... he show me coil pack and said it was burned up there was some burn marks on them so i got new ones he said i got new spark plugs but did not see them so don't know if they are done .this was about 8 months or so the car started to loose power up hills and making turns. all together the car had less throttle response so adjusted the ACC and throttle cable still no luck then one day the cars idle started to jump when driving its kinda like it was adjusting it self but continue all the time, only when driving. this happened for one day or so until it got so bad it would not go over 2000 rpms with out flooring it and then still it would not move like it should .then one day i blow passenger side exhaust going up hill with it floored drove home and fix it the next day the car had this problem where the car would drive fine until wormed up then would not go over 2000 rpm at all. feels like timing is wrong when it worm up so i got a timing light and timed it but that was not it the car backed fired when worm and if i start it and turn off will not start back up
if the cars in park and rev up its it is fine and will go over 2000 rpms but in drive it feels like power is not going to weels and will not event go up car ramps os i can get under it
correct me if i am wrong when its cold it in a pre-programed mode for timing, fuel, and spark. until it is worm up.... when wormed up is when this problem happens . would it be possibly to trick the ecu to make it think its in this safe mode all the time. what happened when ks go bad is it smilier to what happened to my Q or what about injector 0-rings or FPCM to much gas would make it back fire maybe mes with idle and acc try to compensate for raise in idle make it jump
i need some idea 's what this could be any input on problem that would cause any of these symptoms similar problem are also welcome
