crazyboy3012 wrote:Are all of you changing oil at an authorized Infiniti service centre (or by urself) or using other options such as Midas?
Avoid the quickie oil change places - they are not careful enough. Take your own oil filter and oil to a place where they will allow you to see and surpervise the work ... I use a local Goodyear place and a Precision Tune sometimes. I refuse to let them use any old filter though - see below!! If the Midas place will let you observe the work, then fine - just use your own oil and filter.
If I had a safe way to get under my car, I would probably have fun doing it myself though ...
crazyboy3012 wrote:Further am i right in understanding that it really does'nt matter whether you use a regular oil or synthetic?
If you change the oil and oil filter often enough (3750 miles or less, or 180 days or less, regularly, without fail) then, imho, any good oil - dino or synthetic - will do. We had an oil expert here once who recommended Chevron Supreme and Castrol GTX as good dino oils in a 5W-30 weight (10W-30 in hotter climates), and Mobil 1 Synthetic 0W-40 as a good year-round synthetic. I use the Mobil 1 Synthetic in my cars ...
crazyboy3012 wrote:We just have to make sure we use 5W30 or 10W 30..right?
In general, yes. However, depending on your location and how hot or cold it gets, you can vary this a bit. Like in hotter climates, in summer, a 10W40 might be better.
crazyboy3012 wrote:I donno much about oil filters...any input about where can i buy or which one is recommended is highly appreciated.
Stick with OEM filter. Get the filters and copper crush washers (called drain plug washers) from Joe Tsensky at
http://www.everythinginfiniti.com - the price for "six packs" is comparable to after-market filters and you will be sure of quality product.
As a summary: I buy 6 qts of Mobil 1 Synthetic 0W-40 oil (it is a V-8 Infiniti engine, so takes 6 quarts, a bit more than the G35 probably) from Kragen, the OEM oil filter and crush washer from
http://www.everythinginfiniti.com, and the Goodyear place charges me $12.99 to change the oil and filter and dispose of the old oil and filter. Can't beat that for the convenience!
Z
