FYI
notacarlo
Car: 2003 M45, 1986 Mustang SVO
The battery that Interstate calls for a replacement in the 03 M45 pn:MT34R (700CCA/875CA) is incorrect.
If you use their web site to look for a battery and the MT34R is suggested, you should know that the terminals are opposite.
M4T5
Car: 2007 Infiniti M45
How much does an OEM battery cost for the 06' & up M35/ M45's?I kind of like the clear type view to see if it is low on battery fluid.
J
notacarlo
Shows to be the MT-25 Mega-Tron 75 month 550 CCA listed at $94.95-113.95
IMHO that's a pretty weak battery especially if you have lots of "electrical" options.
Can't beat the warranty though.
M4T5
notacarlo wrote:Shows to be the MT-25 Mega-Tron 75 month 550 CCA listed at $94.95-113.95
Are you talking about the factory battery? If so, it's not weak, it is what is necessary to operate the car in the correct manner. High cranking amp batteries are not needed to turn these engines over.I would never opt to a higher amp battery unless I added equipment that will place more of a load on the system than it was originally designed to handle.
J
notacarlo
Roger that.
I also have the AC Delco 24-7YR 700CCA 24 BCI for $153.44
Finding the OEM battery from Nissan/Infiniti will get expensive.
Stay away from Optima.
notacarlo
I wonder who manufactures the Infiniti battery. Everything I have read states they last 7 days past the warranty....
They seem to crap out WITH warning though, as mine did yesterday. Slow cranking the day before and then death.
I had to do a little creative wire re-routing, but I got the Interstate in and it works just fine.
M4T5
notacarlo wrote:Roger that.
So I'm assuming the OEM battery is not available here in the states? I will research and see what I find.
J
M4T5
For those of you who's Infiniti vehicle is still under the original factory warranty might find this useful or useless. Take it how you want.This is noted in the Infiniti Owners Manual under Battery Coverage:
ORIGINAL EQUIPMENT BATTERY COVERAGEThe coverage period is 48 months or 60,000 miles,whichever comes first. A defective original equipmentbattery which is unserviceable within the first 12months and 60,000 miles will be replaced free ofcharge. After 12 months but within 24 months and60,000 miles, you will pay 25% of the replacementbattery’s suggested retail price plus applicable taxes.After 24 months but within 36 months and 60,000miles, you will pay 50% of the replacement battery’ssuggested retail price plus applicable taxes. After 36months but within 48 months and 60,000 miles, youwill pay 75% of the replacement battery’s suggestedretail price plus applicable taxes. Nissan will pay therest, including all labor to remove and replace thedefective battery.
J
jbillion
Car: 2004 M45 Premium Package
No mods, just keep it clean.
2008 Altima 3.5 SL CVT
Yes there was warning. My car had the same symptoms before the battery died a few months ago. I got the Duralast Gold from Autozone which has been highly rated by XConsumer reports. It has more CCA's then the OEM battery and an 8 year limited 4 year replacement warranty.
