the bolt holes don't line up, i'm thinking it's because of the awd that it doesn't fit. looking up with the oil pan off you can also see a tube going from the tcase to the axle so i'm thinking the awd stuff is totally different from rwd. it also looks like you may have to space the swaybar to get it to clear the oil pan if it works on rwd.
maybe this was common knowledge but i hadn't seen anything about it. also failed trying to put on a transmission cooler because there's no place to run the lines without cutting holes in the car.
oh well
