FYI Mobil1 is bad for turbos
sam_bo3
Car: 89 240SX hatch (ca18det swap)
I put synthentic in my car and it started to smoke. 500 miles later and it won't boost past 4 psi and leaves a 1/4 mile smoke screen. The good thing is that you get all kinds of looks at the stop light.
I guess the next step is to find out how bad the turbo is damaged. Is it rebuildable? I have the tools to rebuild it but I think I may let a pro build it just for safety's sake. The turbo has less than 2K on it. If the turbo housing is shot then i may have to give up the CA and go with something that is cheaper to maintain like a sb chevy. I can get a decent one for couple hundred bucks and in a weekend or 2 have it running. I know you folks are purist and don't agree with it but for a daily driver I am leaning toward an engine that has cheap availible parts that aren't needed that often.
How is that oil-related?
Turbo might have had bad seals, or you may have simply overfilled.
themadscientist
I have run Mobil 1 for ten years in the same engine with absolutely no turbo failure. Don't blame your oil when your seals are to blame. Hell It might not be your turbo at all, how old is your engine? A motor with bad blowby would have a hard time spinning your turbo.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
ever bothered to read the back where it says recommended for Turbocharged engines.
Also check your lines and helps to know which turbo it is? As you may not be running the proper lines.
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
not to thread jack but i think my smoking problem might be caused by over filled oil, can you explain this for me...thanks
AZhitman wrote:How is that oil-related?
rico05
Car: 1992 RMS13 w/ CA18DET
I ran Crapsol GTX for the first 500 miles after swapping to clean out any gunk (there was none), then switched to Mobil1 15W-50. 3 years later, she is still kicking (a$$ and taking names that is).
Sorry bud, but your assumption of Mobil1 being your problem is just plain wrong.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Hey, I happen to love "crapsol GTX" as you call it. as far as non-synthetic oils go, its the best.
To the other guy, your car will smoke when it burns off the excess oil. Its just how it works. The oil has to go somewhere, it gets burnt. Happens to the best of us sometimes.
And just for the record, mobil one is fantabulous for turbocharged vehicles.
The_Chosen_One
r34 gtr wrote:Hey, I happen to love "crapsol GTX" as you call it. as far as non-synthetic oils go, its the best.
I've been using Mobil 1 extended performance 15w-50 and just recently switched to Castrol Syntec Blend 10w-40 I like the castrol better.
johngriff
Car: 240sx
I figured I could add some fuel to the fire.
http://www.rpsportengineering.com/OilTests.pdf
Discuss!
themadscientist
I used Castrol GTX before, good dino juice.
r34 gtr
MAXIMUM protection against viscosity and thermal breakdown.
Oh, and John Force approves it. I wish him the best, that was a nasty crash.
iliketocrash
and on a side note. isn't oil that isn't synthetic just... oil? you can't do much to dino oil otherwise it's not just oil is it?
NeedCAforS13
Car: CA swapped S13 coupe
I run castrol gtx as well. Its what we used at the dealership. 40k miles since my rebuild at over 300hp, no hiccups. And its HOT down here :P
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
i use royal purple in the CA and Valvoline synthetic in my jeep
tineira
johngriff wrote:I figured I could add some fuel to the fire.
Discuss!
That test is not so valid. Look at this, http://www.ls1.com.au/forum/showpost.php?p=790778
dlong319
Car: 91 240sx Hatch (ca18det)
Discuss!
This was quite interesting to read. I was surprised with the results they concluded, but it appears Royal Purple for the win.BTW if you go to the Royal Purple website you can see them dyno cars with and with out the Purple stuff.
themadscientist
Mobil 1 was a car oil a motorcycle mag used to test the theory that motorcycles needed motorcycle oil. It scored in the middle ahead of many "special" motorcycle oils. Remember that most bikes bathe their clutch packs in the same oil the crankcase uses. You think a turbo engine is rough on oil try being torn at by clutch plates.
rico05
Aw, there is nothing wrong with GTX. It is indeed the best dino juice for sure. I just don't like Castrol (or BP) as a company. All the crap with the Amsoil/Mobil1 lawsuit and all. I am just one of those consumers that buys the company, not just the product. I only buy Shell VPower, 3M adhesives, Permatex sealers, etc.
Zero260
Car: 91 240sx coupe
good thing I've dicided to run Royal purple, that just makes the extra 30 cents a qt. over mobil 1 all the better deal.
themadscientist
you should read more than the thread title.
The_Chosen_One
themadscientist wrote:you should read more than the thread title.
I think hes refering to the article that Johngriff posted, the article showed that Royal Purple was pretty much at the top.
