rsagen »
https://forums.nicoclub.com/rsagen-u135980.html
Fri Feb 19, 2010 3:33 pm
When your check engine light goes on, it is because you engine senses a problem with one of its many sensors and wants to let you know of the problem. When this happens, you should pull the ECU (located behind the plastic shield on the right hand side of the passenger side foot-well), run the diagnostic test (instructions below), read the code, and fix the problem (replace the sensor or whatever).
Once you’ve pulled the ECU and located the ‘mode selector’ screw on the side...
Turn the ignition switch to the on position, but do not start the engine. All of the 'dummy' lights in the dash should be on.
Turn the 'diagnostic mode selector' screw on the side of the ECU fully clockwise. The check engine light will go out. Now wait at least 2 seconds, and then turn the screw back to its original position (fully counter clockwise).
The check engine light will then begin to flash the trouble code -
The number of long flashes is the 1st digit, and the number of short flashes is the 2nd digit...
So for example, a code 45 would be:
blink........blink........blink........blink - (short pause) - blink...blink...blink...blink...blink
