FY33 transmission drop
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
Ok guys dont laugh - I have never done this before....
97Q - transmission pan drop. Can anyone who has done this do a complete write-up on this. How many bolts are there to open to drop the pan. I see many small bolts (screws) around the base of the pan - do those have to be opened???
I dont want to screw up anything - I would appreciate a detailed write up by anyone who has done it recently.
CJ
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
I dropped my Y33's pan last year. In addition to the pan bolts (about 15 or so), I had to remove 2 or 3 other bolts for the fuel or brake line bracket (I didn't know if it was a fuel line or a brake line). The line [metal] was in the way of 1 or 2 pan bolts.
5zigen
I would like to know too... thanks to whoever posts up the full guide.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Do you have the manual and TSB? If not, go download them.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The manual doesnt help much in this regard...
The G50 has the same transmission (for all benefits and purposes) so any guides you find on the G50 will be identical to the Y33
CJQ45
The manual doesn't help... it gets into more complex stuff like checking hydrolic pressure and solenoids. Doesn't talk about a simple pan drop.
I want to do the drop this summer... I have never done it - just want to be safe than sorry
Pictures would be greatly appreciated
elwesso
2007 BMW M Coupe
http://www.q45.org/pandropsensors.html
Theres some pics and a writeup.. Should be 99% the same..
What I would do next time that I didnt include in the article, is let the pan drain overnight.. Drain it when its hot, and then let it cool overnight. You dont want to work on the transmission when its hot, but ideally, youd like to get the fluid out while its hot....
Go every few hours and move the shifter to a different location.. I remember moving my shifter around, and every time i moved it the flood gates would re open. just when I thought i didnt have enough ATF in my hair!
5zigen
Wes... post up the '97 FSM if you can on your website if you can anytime soon.
elwesso
2007 BMW M Coupe
Will do today!!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
CJQ45 wrote:The manual doesn't help... it gets into more complex stuff like checking hydrolic pressure and solenoids. Doesn't talk about a simple pan drop.
Probably becasue it is so trivial for a technician. It really is very straight forward.
FSM without the TSB if only part of what you need.
