Fx50 2010 issues
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
Rasheed
Car: Infiniti fx50 2010
Fx50 2010
Hello every one , i need help cause i cant figure out what would be the problem, few weeks ago i changed the spark plugs for my car and two days later i noticed the below symptoms:
1- water drops from tailpipe and continuous vapor , could be coolant.
2- when car is cold, coolant reservoir is above the limit and less when checked the cap in engine.
3- battery positive holder fuse blown, replaced it and blown again at cold start.
3- coolant is missing like 150 ml every four or five days.
Two days ago engine started to vibrate a bit at idle or low speeds.
I really appreciate any ideas on what could be the problem .
Thanks all and always was able to find answers on this great forum.
Ilya
Moving this to the correct forum.
Rasheed
Which one?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Deleted duplicate thread.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
