firepwr »
https://forums.nicoclub.com/firepwr-u26826.html
Sun Aug 05, 2007 7:08 am
Hey guys-As far I know, I was the first to put on the FX45 20" wheels on a Y33, first with 225/30/20s (worried about clearance with 1" Eibach springs) and then 235/35/20s. Since, I've cracked 3 rims. They are crack on the inner lip, about an inch or two, just enough to leak out air. I'm up in Madison now, and the mix of the cold and overfilled tires (do not trust your local Jiffy Lube to put in the correct amount of air) may have had something to do with it, but in any case the lips of the FX45 20" wheels are prone to cracking with low-profile tires.Has anyone else had this problem?
