FX35 tire width upgrade???
jb88061
Does anyone know the widest tire that will fit on a 20x8 rim on an FX 35 without significantly changing the tire diameter. I run the stock 265/50R20, but am wondering if something like a 305/40R20 would fit.
Any help will be appreciated...
Joe
Nismo_Freak
Car: 89 Nissan 240SX
In a 305 width the best you can do is a 45 aspect sidewall and requires a 9.5" wide wheel minimum.
I think your best bet would be a 275/45/20 and that would be pinched onto the rim (meaning the rim is slightly out of it's specified fitment range).
I'd suggest OEM sizing for the time being.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
the biggest you can fit on OEM wheels would be 285/50/20...
Nismo_Freak
Checkered-Member wrote:the biggest you can fit on OEM wheels would be 285/50/20...
That would increase the rolling diameter considerably.
Checkered-Member
Nismo_Freak wrote:That would increase the rolling diameter considerably.
Stock is 265/50/20 which makes the diameter 30.43 While with 285/50/20 the diameter becomes 31.22
a .79" difference or 2.5% larger…is that really allot?
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Yes, that is well beyond what we would put on the vehicle. I would stick to within 3/10" on the O.D. of the tire.
