The rear sub mounted on top of the spare keeps cutting out. I've pulled it out a couple times and checked the plug wiring and wiggled everything around. I used to think that something was lose since it would sometimes come back on when I hit a bump. I've even gone as far as opening up the amp and resoldering everything and cleaning the main harness leads. It is still doing it. Basically, after a couple of minutes it cuts out then back on a few minutes later. It will do this merely sitting in the driveway. I'm thinking something is either overloaded (bad thermal) or maybe that relay in there. Any ideas? I hadn't checked with repairs from Bose yet. I know that I had sent my door speakers from my old Q and had them rebuild them years ago. I just wanted to see if it's something easy before I spend more money.
Thanks much,
Robert
