FX35 Ashtray door sticking
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
Stone Lion
Car: 2012 Infiniti FX35
Hello all,
I am new to the forum as of today.
I have an issue with the ashtray door not opening all the way on my 2012 Infiniti FX35.
It closes and latches as it's supposed to, but only partially opens.
Doesn’t even open enough to use jack!
Has anyone else run into this?
I'm afraid I'm going to break it trying to get it out to see what’s stopping it!
Thanks in advance for any ideas.
Reason: Revise title
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome!
Try lightly spraying the hinges with either WD-40 or similar silicone lubricant.
I believe the instructions for removing the ashtray are as follows:
1) Remove the shift knob (pull down boot, there's a small metal clip, take it out, DON"T LOSE IT, pull up the knob).
2) Use a plastic blade and carefully pry off the shifter panel (not the chrome piece, the bigger aluminum piece). Start from the front part on one side and slid the blade carefully while pulling lightly up. The thing is held in place with clips. It's easy to take it out once you get some confidence in yourself).
3) Unplug the two harnesses for the shifter and take out the panel.
4) You'll see two screws at the bottom of the ashtray. Unscrew those. There might be two more screws under the radio face plate, but not sure.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
