stuart »
https://forums.nicoclub.com/stuart-u12577.html
Mon Nov 17, 2003 6:42 pm
I have a 2004 Murano SE that is giving me and Nissan big headaches, The tire warning light comes on as well as the information screen beeps and tells me that my tires a low. This is great as this is how it should work, it shows each tire and what air pressure is in them. Well the tires should be 33 psi, it has been cold so the warning light and the buzzer,and screen comes on shows flat tire then each tire with 27psi 27psi 26psi 27psi. Fill tires up to 33psi, then use a digital tire gauge that is dead accurate. The screen says only 30psi,dealer puts tires up to 36psi and tells me to drive it, the screen show 33psi no buzzer no warning light. Great now my teeth and head bounce around like a nodding doll. Today the temperature was warmer and my tire pressure on screen show 40psi, drop it to 33psi and it works ok. But my point to Nissan is when it gets cold i have to put 36psi in the tires to stop all my problems and the ride is awful, there responce is we do not have a fix.::
