Thorshammer wrote:1. low fuel warning light is useless2. awd anti lock system is noisy3. doors do not auto lock4. weak retraction spring on large side rear seat.5. A wheel pressure system that does not identify the wheel it is monitoring.6. fuel door with a mind of its own.
Yes, I own a 2008 FX45
1. Why do you let it get down that low in the first place? Do you not have a clever monitor in your center dash that lets you know how low you're getting? I have an idea... why not refuel when you're getting low? Say when you have 100 miles till empty start thinking about getting gas and when you get below 50, really start thinking about getting gas. That's what us "smart" people do
2. Does your ABS system not work? Who cares if it's loud as long as it works. I've driven some pretty crappy ABS systems that are quiet... I'd much rather they work. I usually try to drive within the limits of the car and stay away from using the abs system but that's just me
3. As you state, the car isn't designed to do this. My wife's car has it and I've disabled it. Why would you want this? Do you really think you're going to accidentally try to open the car door, undo your seatbelt and ACCIDENTALLY fall out of the car?!? C'mon. Those autolock features are death traps when you get in an accident
4. Mine works fine
5. I'll give you this... it's annoying. But nothing a tire pressure gauge can't fix. The screen lets me know that I've got one tire way out of whack so I go around and find out which one it is... and I fix it!
6. I don't have a problem with mine. Are you referring to the door popping open when you unlock the car? If someone bumps your fuel door or pushes to open it while the car is locked, when you unlock it, it'll pop open. Maybe someone's screwing with you? Mine works as expected though
Now, do you not enjoy DRIVING your FX? Stop worrying about petty stuff and enjoy the ride
