jtesensky »
https://forums.nicoclub.com/jtesensky-u413.html
Mon Mar 29, 2004 5:47 am
Hello, & welcome!1.) I wouldn't suggest disabling the AWD system. A lot of the electric/diagnosis components work on combination with each other. If you disable the AWD system this could lead to other problems.
2.) There is a feature in the info system that you can go into to remove the reminder messages, I believe it is under "Maintinence". It will be in the same place you can turn off the oil change reminder. You may want to check your owners manual, I know they state where to go in there.
Cheers!-Joe
