imnprsd »
https://forums.nicoclub.com/imnprsd-u304061.html
Wed Jan 18, 2023 7:30 pm
ONE SOLUTION TO THE LIGHT COMING ON IN THE DASH ==> Just disconnect the wires to the sensor or easier still just cut and tape the wires. The latter will leave the connector on the pump motor which maybe better if you just want to turn the light on the dash off for good!
Note: I think the pump motors are the same for all model years, and some cross to Nissan models, but what the do is change the type of connector and then give it a different part number. (Sneaky.) That said, if you really want your dash light to work, just buy a new (cheapest Nissan sensor you can find) and then cutoff the connector... and just solder or crimp the wires to make a connection.
It was not hard to get to and only took 30 minutes. Just remove the skid covers on the passenger side, between the wheel well and the engine skid cover. You don't have to remove the fender skirt. Just wedge a 1" flash light or other object to expose the bottom of the washer tank and then pop out the electrical connector.
Pull the electrical connector apart and then seal it with electrical tape. This will permanently "open" the circuit and your dash light will go off. Of course your Washer Dummy Light will never come on again, but who cares! Just be sure you keep fluid in your tank so you don't overheat the wiper pump motor.
Note: Disabling the power to the sensor is easy, but removing the sensor it self (Part #28911CG000) is a lot more work, because you have to gain more access to this area. The sensor can still be bought for $135 list, but my Infiniti Dealer quoted me $80. I would have ordered one, but I did not want to spend a lot time removing the bumper cover. So this repair did not cost me anything and now my washer light on my dash is "off" for good. No worries. I'm satisfied.
- 2003-8 FX Washer Fluid Level Sensor.jpg (52.89 KiB) Viewed 1198 times
- 2004 FX45 Wiper Tank & Washer Motor.jpg (51.55 KiB) Viewed 1198 times
